Measurement Studio for VB6
Looking for example code to do buffered Digital acquistion using external clock (Visual Basic 6 and DIO32-HS card)
I'm trying to do clocked digital input with a DIO32-HS card using VB (I've got an extrenal clock signal fed into the card). I have seen the Burst examples but not any that use buffered acquisition. Does anyone know where I might find some example code to do this using VB6?
Thanks in advance.
(5,858 Views)
If you have a look in the program files/national instruments/ni-daq/examples/vbasic/di directory you will find a few examples of DI. I have attached DIdoubleBufPatternGenExtClock653x.FRM which is an example of Digital input with an external clock for the 6533.
Kind Regards
Tristan
(5,858 Views)
