Measurement Studio for VB6
Masking regions with CWIMAQViewer
OK,
Having difficulty setting a region or mask on an image and then just sending that selected region over to CWIMAQVision.Threshold and CWIMAQVision.BasicParticle to get a pixel contrast count.
Both methods require a CWIMAQImage as the source image. I accomplish it just fine sending my entire source image, but I want to just sending something which is inside a drawn rectangle.
I have 2 CWIMAQViewer controls side by side. The first displays my raw image, the second displays my RED on BLACK Particle image. I want to draw a region on the left CWIMAQViewer and then just have what is inside that region be particle'd and show up in the right Viewer Control.
I was trying the RegionsToMask method which was putting the shape of the mask into the other CWIMAQViewer control. But I can't figure out how to pass what might be inside that Region I selected off to the Threshold & BasicParticle methods.
Any Ideas?
(6,647 Views)
Try looking at the Histogram example that installs with IMAQ Vision under C:\Program Files\National Instruments\Vision\Examples\MSVB.NET\2. Functions\Analysis (if you are using .NET - if not, change the MSVB.NET folder to MSVB).
This example shows how to use a ROI and create a histogram from that ROI.
As for functions that do not have a mask input, use the RegionsToMask Method (CWIMAQRegions.RegionsToMask DestImage [, UseModelImage = True] [, FillValue = 255])to create a Mask from a selected Region of Interest and then use the Mask Method (CWIMAQVision.Mask ( SourceImage, MaskImage, DestImage)) to copy the portion of the image you want into another image buffer - DestImage. Then use that DestImage as the image input for your Threshold and BasicParticle methods.
I hope this helps. Good luck with your application!
(6,642 Views)
That works like it should with teh sample code, and I modified the sample Project called Mask so that what I selected with a Square appears in the second viewer. (The original version of that sample is a Click in the original viewer and then the contents of what fills the "Mask" picture appears in teh second viewer. Anyways,
In my project when I Select my range and copy that contents with the .MASK method the mask part of the image is copied to my second viewer as a RASTER snow image. It ain't copying like the same code in the sample.
Could my CWIMAQViewers not be U8, as I think that they must be. But if that is the case, how would I set it.
Not aswell. I can do everything fine the same Images in the MASK sample as I am trying to use in my project.
If we can get that, then we're all set.
Thanks again
(6,638 Views)
The CWIMAQImage.Type will set the image data type of the buffer you have setup. The possible Data Types for CWIMAQImageTypes are:
cwimaqImageTypeComplex–Complex.
cwimaqImageTypeHSL32–32-bit HSL.
cwimaqImageTypeI16–Signed 16-bit.
cwimaqImageTypeRGB32–32-bit RGB.
cwimaqImageTypeRGBU64–64-bit unsigned RGB.
cwimaqImageTypeSGL–Single precision.
cwimaqImageTypeU8–Unsigned 8-bit.
This is all in the IMAQ Vision for Visual Basic Reference Help which can be found at:
Start»Programs»National Instruments»Vision»Documentation»IMAQ Vision Visual Basic Reference Help.
Hopefully this will solve your problem. Good luck with the project!
(6,631 Views)
