Measurement Studio for VB6
Measurement Studio Evaluation Software - Instrument Driver Factory
Greetings,
I have a copy of the Measurement Studio Evaluaiton Software CD. I've
installed the Labwindows/CVI Demo and Component Works Demo. Wanted to
check out the Instrument Driver Factory (located in VB\Instrument
Driver Factory). When I launch IDF.exe I get an error which states
that I have to install Labwindows/CVI. I tried the installation a
couple of times with the same results.
Has anyone else had this problem?
Rick
(3,472 Views)
Hi!
I would like to reproduce the problem on a test machine. Could you please tell me what OS you are using, and if you have any other NI softwares installed on your machine. Also, am I correct that you have Measurement Studio Evaluaiton Software for version 6?
Mika Fukuchi
Application Engineer
(3,472 Views)
Mika,
I have tried the installation on two machines.
The first system has Windows XP Pro along with Labview 6.0.2 / MAX /
PCMCIA-GPIB / Visual Basic 6.0 / Visual Basic.Net
The second system has Windows 2000 and Visual Basic 6.0
The Instrument Driver Factory error reads:
The ComponentWorks Instrument Driver Factory cannot locate
Labwindows/CVI. In order to use the factory, please install
Labwindows/CVI version 5.0 or greater.
The Measurement Studio Evaluation Sofware CD installed Labwindows/CVI
5.5 The CD picks a path of "C:\MeasurementStudioDemo\CVI\"
The Instrument Driver Factory is installed in
"C:\MeasurementStudioDemo\VB\Instrument Driver Factory\"
The Instrument Driver Factory is installed when the Component Works
for Visual basic is
installed.
The part number on the installation CD is 350654B-00
Thanks for your help.
Rick
On Mon, 25 Nov 2002 14:00:06 -0600 (CST), mfukuchi wrote:
>Hi!
>Mika Fukuchi
>National Instruments
(3,472 Views)
Hello Rick,
I have some suggestioins, but it would be probably better if we could communicate directly. Could you please go to www.ni.com/ask, and fill in the request for an email support. In the desscription section, please say that you have been communicating with Mika Fukuchi. We'll go from there!
Mika Fukuchi
(3,472 Views)
Tried the install on a third system. I put in a request on the /ask
page and will call-in on tuesday.
On Tue, 26 Nov 2002 09:12:16 -0600 (CST), mfukuchi wrote:
>Hello Rick,
>go from there!
>Mika Fukuchi
(3,472 Views)
