Measurement Studio for VB6
Measurement & Automation: MAXStoppedServiceError, MAXServiceNotStartingError
I use Measurement&Automation Explorer.
I try to simulate the measurment device "PXIe-4300", but MAX has various tiemout problems:
- MAXStoppedServiceError
- MAXServiceNotStartingError
What could I do to change the Measurement & Automation Explorer? I need MAX to run constantly as I wish to test an electrical appliance.
Thanks for your help.
(7,902 Views)
Hello Mr Schindler,
Could you please let me know which version of DAQmx you are using?
This error usually happens when the NI Configuration Manager service is not properly started. Tu restart it, open the start menu and Execute services.msc .
Look for the NI Configuration Manager service, right click on it and restart it.
please let me know if it solved your problem.
Best regards
______________
Florian Abry
Inside Sales Engineer, NI Germany
(7,898 Views)
thanks for your help. I use DAQmx Version 9.3.5.
The Measurement&Automation Explorer runs, as I have used the Windows-Service.
Now another problem occurred:
I want to work with the simulated instrument "PXIe-4300", but the self-test was not successful.
229823
" Internal Wiftware Error in MIG Software. "
Best regards.
(7,888 Views)
I am glad to hear your problem is now resolved. Could youplease mark the previous post asd answer in order to help other customer facing the same problem and looking for a solution on the forum?
Best regards
______________
Florian Abry
(7,881 Views)
