Measurement Studio for VB6
Microsoft Word Templates and ActiveX Control Problems
I am experiencing a strange problem in Microsoft Word. I am writing a VBA application which displays a cwgraph in a form. If I add the graph to a form in the Normal.dot template the control is fine. If I add the graph to a form in a new template (where all my code is) the graph displays evaluation copy. The graph in the Normal.dot template is fine and displays without the licensing information and in the properties it displays the correct licence code etc.
Has anyone experienced this before and got any suggestions.
Thanks in advance.
Regards.
Joe
(7,279 Views)
Hi Joe,
There have been a few issues with licenses and ActiveX controls in Measurement studio. There is a License fixer utility to correct some of these:
http://digital.ni.com/public.nsf/websearch/86256A47004E16D186256A99007BEFB7?OpenDocument
Regards
Jon B
NIUK
(7,245 Views)
Jon.
Thanks for the reply. I have already run the license fixer utility and it does not locate any broken licenses. I have also uninstalled everything and deleted cwui.ocx in System32, then reinstalled and tried again. The strange thing is that it works in Visual Basic standalone, in the normal.dot template in Word. It just doesn't work in a different template file.
Thanks.
Joe
(7,241 Views)
Jon.
Do you have any other suggestions on how to fix the problem. I need to release some software to a customer and it can't go with evaluation copy in the graph.
Thanks.
Joe
(7,225 Views)
