Measurement Studio for VB6
More CWGraph / Array Questions
I have a two dimensional array of Y values, lg_measurement(0 to 10, 0 to 5). In real life these are 6 different sets of 11 channels of A2D readings -- which are sampled periodically. The array is overwritten with new data with each periodic sample. I would like to be able to make a scrolling chart that of these values in a CWGraph. I would like to control which channels are displayed with 11 checkboxes and from which dataset to display with a drop-down selection list. Hhow do I pass the array to the cwgraph control so that have control over what is displayed in the way described?
(6,556 Views)
To chart the two dimensional array, pass the array to the CWGraph.ChartY method.
To control which channels are displayed via CheckBoxes, you can create a control array of CheckBoxes, add a Click event handler for the control array, then retrieve the plot at the associated control array and set its Visible property accordingly. For example, add a checkbox, select it and press Ctrl+C to copy it, and then paste it. Visual Basic will prompt you with a message that says "You already have a control named 'Check1'. Do you want to create a control array?" Click Yes, then keep pasting CheckBoxes until you have your 11 CheckBoxes. Double-click on one of the CheckBoxes to create an event handler for the control array, then add the following code:
Private Sub Check1_Click(Index As Integer)
' Get the plot at the corresponding control array index and set its
' Visible property to the value of the CheckBox.
CWGraph1.Plots(Index + 1).Visible = Check1(Index).Value
End Sub
I'm not 100% sure what you're trying to do with the drop-down selection list, but if I'm understanding it correctly, I think you'll have to keep track of what set of data is associated with each item in the list and when a different item is selected, you'll have to replot the data that's associated with that item.
- Elton
(6,550 Views)
End Sub
- Elton
OK, the checkbox array makes sense. To claify what I am trying to do: from this two dimensional array I have 66 datapoints that are charted -- 11 channels in 6 sets. I want to have controls to make individual plots visible or invisible, by channel and by set. So I would like the check boxes to control which channels are visible, and have a dropdown combo selector to control which set is visible. The data is all 'Y' data -- the CWGraph is run in strip chart mode with a history of several hundred data points.
(6,542 Views)
Unfortunately, there is not an easy way to do this. You'll have to implement something to explicitly handle this case, such as replotting data as I briefly described in the previous post.
- Elton
(6,533 Views)
OK, Thanks for your help!
(6,531 Views)
