Measurement Studio for VB6
Multiple Voltage Outputs using DAQmx in VB6
I'm trying to get multiple DC voltage outputs from the same board (NI USB-6251) at the same time.  I able to accomplish by creating a tasking in MAX, but not sure how in VB6.  Was using the sample program 'ao_single_point' as a start, but its only setup for a single channel. I tried to modify the code to add-in an additional channel, but recieved an error (-201489), and I'm not sure even if the channel added in how to change the voltages of the channels.
(5,928 Views)
Hi John,
Have you tried looking at the examples we ship with our DAQmx .NET support? They are wonderful resources for getting started with reading from our hardware. You just need to make sure that you enabled the NI-DAQmx API for .NET when you installed your DAQmx driver. If you did not, please look at this knowledge base article entitled Do I need Measurement Studio to use NI-DAQmx in .NET. Hope this helps. If there is anything else I can do to help, please let me know. Thanks!
~kgarrett
District Sales Engineer
(5,910 Views)
