Measurement Studio for VB6
NI6221数据采集卡 用VB编写AO通道程序 出现了些问题
 往AO通道送数据的时候 数据感觉总是送不进去
不知道问题出现在哪里?
我把ao程序段贴下,希望各位高手帮帮忙:
Private Sub AO(double MV)
        Dim numSampsPerChannel As Integer
        numSampsPerChannel = samplesPerBufferTextBox.Text
        ReDim data(numSampsPerChannel)
'  Create the DAQmx task.
        DAQmxErrChk DAQmxCreateTask("", taskHandle)
'  Add an analog output channel to the task and check to see whether there is only ONE task.
        DAQmxErrChk DAQmxCreateAOVoltageChan(taskHandle, "Dev1/ai0", "aoChannel", -10#, 10#, DAQmx_Val_VoltageUnits2_Volts, "")
 '  Write to the desired channel(s).
        DAQmxErrChk DAQmxWriteAnalogF64(taskHandle, numSampsPerChannel, True, 10#, _
        DAQmx_Val_GroupByScanNumber, MV1, sampsPerChanWritten, ByVal 0&)
   MV=MV1
      Exit Sub
ErrorHandler:
    If taskIsRunning = True Then
        DAQmxStopTask taskHandle
        DAQmxClearTask taskHandle
        taskIsRunning = False
    End If
    generatingLabel.Visible = False
    CmdStart.Enabled = True
    CmdEnd.Enabled = False
    MsgBox "Error: " & Err.Number & " " & Err.Description, , "Error"
End Sub
希望高手们多多帮忙~
Message 1 of 1
(7,366 Views)
