Measurement Studio for VB6
Need Component Works
Some old programs for my measurment system (Lab PC+ control via LAN\Internet) were written in Component Works v3.0.1. Distributiv is lost =( . Is it possible to download it? If this project is closed should I need Measurment Studio?
Thanks a lot.
Paul
(6,399 Views)
Paul,
The Component Works ActiveX controls install with the driver software.  According to the driver support page, the latest version of NI-DAQ that supports the Lab PC+ is version 6.9.3:
http://www.ni.com/support/daq/versions_legacy.htm
However, this may consist of a later version of CWDAQ than 3.0.1.  The interface for the controls should be the same, so your old code should be compatible with the updated version of Component Works.  If you run into problems, you may try installing prior versions of the driver, which you can find at this web page:
http://digital.ni.com/softlib.nsf/webcategories/85256410006C055586256BBB002C1293?opendocument&node=132070_US
Good Luck!
Tyler Tigue
(6,377 Views)
