Measurement Studio for VB6
PCI 6036E/SC 2075, can read only from ch 2, need to use both. help please
I have interfaced DAQ PCI 6036-E with SC2075. I wrote a code to get data from analog input chl 1 and ch 2. I am getting data only from ch1. cables and hardware connected to sc2075 had been tested and are working properly. help please .Also, is it possible to test those channels from measurement and automation explorer and how ?.thanks
(6,095 Views)
Greetings,
Yes, it is possible to test these analog input channels in Measurement & Automation Explorer (MAX). To do so, expand Devices and Interfaces, right-click on the PCI-6036E, and select Test Panels. On the Analog Input tab, you can set the Channel control to any of the device's channels. If both CH1 and CH2 function correctly in MAX, you will need to troubleshoot your code.
Good luck with your application.
Spencer S.
(6,095 Views)
