Measurement Studio for VB6
Painting problems with cwgraph in multiple document interface (mdi).
Has anyone else seen weird behavior when using a cwgraph on an MDI child form in .NET. Whenever I open a new child window (containing a cwgraph) it gets painted once in the correct location and again offest about 50 pixels away and the old original location doesn't get invalided properly.
The only workaround I've found is to contain the cwgraph in a panel or groupbox and the problem seems to go away entirely.
(3,200 Views)
Do you only see this problem with the graph, or do you see it with other Measurement Studio controls as well? Do you have any other ActiveX control on an MDI child and if so, what is the behavior of those controls? Could you please post a small test project that reproduces the problem? Thanks.
- Elton
(3,200 Views)
