Measurement Studio for VB6
Particle Filter Error
The following code is given in the IMAQ Vision documentation for conducting a particle filter
Dim i As New CWIMAQImage
Dim data As New CWIMAQParticleFilterData
' Select particles that contain less than 100 pixels or
' more than 300 pixels and remove them.
data.Add
data(1).Parameter = cwimaqParticleArea
data(1).MinValue = 100
data(1).MaxValue = 300
data(1).Exclude = True
' Perform the particle filter operation and
' store the result in i
CWIMAQVision1.ParticleFilter CWIMAQViewer1.Image, i, data, True
However it generates the following error for me when doing this on a binary image.
Run time error ‘438’ - Object does not support this property or method which is generate
d by the line in the code
same is also true for the line
but not
Has the syntax been changed from that in the documentation? I want to be able to filter aprticles based upon size criteria
(3,621 Views)
Dear enthusiast,
I really don't believe the problem is with the binary image, and I know that the documentation is old.Please try the following code and let us know if it works for you:
Dim myRange As CWIMAQRange
data.Add
data(1).Parameter = cwimaqParticleArea myRange.Initialize 100, 300
data(1).Range = myRange
Nestor Sanchez
Nestor
(3,621 Views)
Nestor,
Is there anywhere you can download new updated documentation for the Vision software?
(3,621 Views)
I Tried this code which also does not work! The line data(1).Parameter = cwimaqParticleArea myRange.Initialize, 100, 300 generates an error in VB "Expected End of Statement" after cwimaqParticleArea. So VB does not expect cwimaqParticleArea to have any parameters passed with it!
(3,621 Views)
Bashbam,
This is the way it should be.
Nestor.
Nestor
(3,621 Views)
