Measurement Studio for VB6
Plot orbits Graph in VB6?
How to plot orbital plot in vb6? Which component (CWgraph or CWgraph3d ) suppose to use.Thanks.
(7,775 Views)
I am not quite sure what is involved in an Orbital Plot, but you can make the decision about which graph to use based on the dimensions of the plot.  If it is a 2D object (x,y) then you would use the CWGraph, if its 3-dimensional (x,y,z) you want to use the CDGraph3D.  Then you can simply convert the formula or data into arrays and plot these point by point or using surfaces if necessary.  The examples that ship with Measurement Studio for VB6 should be helpful.
John B.
(7,764 Views)
Thanks John,
       Attached picture of orbits graph that i want it. May be u have some ideal to plot it.Thanks.
(7,708 Views)
