Measurement Studio for VB6
Plotting based on time
Measurement Studio Standard Version.
I collect 3 sets of data from a PLC each set of data is collected by the PLC over a given time period.
For example:
My first set of data is collected over 10 seconds.
My second set of data is collected for 3 seconds starting after 2 seconds.
My third set of data is collected for 4 seconds starting after 4 seconds.
I need to plot these 3 data sets on a graph.
The number of data points in each set is random. In other words. Dataset #1 may contain 10 values or it may contain 100. I read the PLC to find the length of each data set.
The X scale should always read from 0 to the longest time, in this case 10 seconds.
Lets say that dataset 1 has 100 values, data set 2 has 30 values and dataset 3 has 60 values.
I know that dataset 1 has 100 values collected over 10 seconds, so there are 10 data points per second.
I know that dataset 2 has 30 values collected over 3 seconds, so there are 10 data points per second.
I know that dataset 3 has 60 values collected over 4 seconds, so there are 15 data points per second.
I need to plot these 3 data sets so that data set 1 will start plotting on Plot#1, after 3 seconds dataset 2 will start plotting on Plot#2 and after 4 seconds data set 3 will start plotting on Plot#3.
In summary,
Plot#1 will have 100 y-axis values plotted between 0 an 10 on the x-axis scale.
Plot#2 will have 30 y-axis values plotted between 3 and 5 on the x-axis scale.
Plot#3 will have 60 y-axis values plotted between 4 and 8 on the x-axis scale.
Is this possible?
Bob Hiller
(6,735 Views)
Bob,
The CWPlot.PlotY function accepts two optional parameters:  xFirst and xInc.  You can use these parameters to start the plot not on the origin.  For instance:
CWGraph1.Plots(1).PlotY plot1, 0
CWGraph1.Plots(2).PlotY plot2, 40
CWGraph1.Plots(3).PlotY plot3, 60
This will display three different plots starting at the 0, 40, and 60 x value.
Attached is an example that plots three different sets of data of varying lengths at different starting points.
Let me know if you have any questions.
Tyler Tigue
NI
(6,720 Views)
Tyler,
I modified your Command1_Click as follows:
Private Sub Command1_Click()
    CWGraph1.Plots(1).PlotY plot1, 0        'Plot plot1 starting at 0
    CWGraph1.Plots(2).PlotY plot2, 30       'Plot plot2 starting at 30
    CWGraph1.Plots(3).PlotY plot3, 40       'Plot plot3 starting at 40
End Sub
This matches my example of:
    'Plot#2 will have 30 y-axis values plotted between 3 and 5 on the x-axis scale.
    'Plot#3 will have 60 y-axis values plotted between 4 and 8 on the x-axis scale.
(6,717 Views)
Tyler,
I will try again. I modified you Command1_Click sub as follows:
End Sub
This reflects my sample data:
First in this example I need the X axis to Read 0 to 10, not 0 to 100. In other words I would like to specify what the X-Axis scale reads.
Secondly, The 2 and third plots start in the correct place on the x-axis but they do not end up in the correct place.
Pleae read this agian and let me know if it is possible
Thank you,
Bob Hiller
(6,717 Views)
Bob,
The third parameter of PlotY is xInc, which can be used to plot the points between a range.  Replace the three plot commands with the following:
CWGraph1.Plots(1).PlotY plot1, 0, ((10 - 0) / 100)                  'Graph 100 points between 0 and 10
CWGraph1.Plots(2).PlotY plot2, 3, ((5 - 3) / 30)                      'Graph 30 points between 3 and 5
CWGraph1.Plots(3).PlotY plot3, 4, ((8 - 4) / 60)                      'Graph 60 points between 4 and 8
The general formula for plotting points should be
CWGraph1.Plots(plot).PlotY plotData, xStart, ((xEnd - XStart) / numPoints)
Tyler Tigue
(6,682 Views)
