Measurement Studio for VB6
Problems with GOOP references.
I've got two questions:
1) I'm trying to create a array that contains references to several different GOOP objects (of different types). The solution I'm using at the moment is to create a array of clusters, where each cluster contains a number and a string and I store the references by calling the flatten to string vi and saving the type and the data string. Does anyone have a better solution.
2) My second problem is that at run time I need to reconstruct the references and make a call to a VI according to the type of reference. My first problem is to identify the type of the reference and the second problem is how to make the separate calls.
(3,044 Views)
This is a LabVIEW question and should be posted to the LabVIEW section here so LabVIEW users and experts can respond.
Best Regards,
Chris Matthews
(3,044 Views)
