Measurement Studio for VB6
Problems with lab view DLL in vb6
Idea: I used vision assistance software of lab view 8.2.1 to make image OCR. That image is captured live by a Sony camera. I applied different functions to obtain the OCR. Then I created a VI using vision assistance tool that came with lab view 8.2.1. Within that I have another sub I use to take the result and it put it into a XML file. After that I made a DLL to be able to use the VI in another PC using VB6 program. I followed the steps that are in the page of NA page to create the DLL. Once it was created I made an installer to be able to take it to the application in VB6. That installer contains the DLL and I also VIs used for the DLL and the lab view Runtime.
Problem: I have the application in VB6 already and the DLL instance in the code and when I execute it not create the XML file with the information that I need. The thing is that I made an example that add two numbers and keeps the result in a XML and it works. Also it is in a DLL like the previous thing. The only thing I think is missing is that I need something installed in addition to lab view runtime to be able to use the vision function of lab view. If any of you have any idea of how I can resolve this issue it would be good.
Files
(7,145 Views)
Hi Gundan01!
In order use an application that includes VI's from the Vision platform you will need a Runtime and a License. The runtime is free but you need to pay for the license in order to use it. Maybe your problem is related to that. Ill check your code and if i find something wrong, i'll let you know.
Have a great day!
Oswald Branford
(6,976 Views)
