Measurement Studio for VB6
Programming tools for Key Word Protocol 2000 (KWP2000)
I need to communicate with an ECU using KWP2000 via Visual Basic. This is the k-line on the ECU (diagnostic line). Ideally, I would like this tool to read a map file or ASAM database automatically (for reading the memory addresses). Then I could read/write memory locations using this tool.
The only software I know about is Vector Canape. But it does not give me the flexibility I need.
(3,613 Views)
Hi Joe,
i am also searching the solution for the same problem.
By the time if U have found then please let me know.
Regards
(3,613 Views)
