Measurement Studio for VB6
Questions about example FFT
I"m working on a project of analyzing analog signals (from VB6) and I'm trying to understand the FFT example.
1.  How does the zooming works on the graph.  I wasn't able to see it.....not in the program and not in the properties of the graph.
2.  I expected to see a frequency on the X-axes and what I see is the number of samples.  Can anybody explain it?
3.  My present objective is to plot the signal on a frequency domain graph where the X-axes is frequency and the Y-axes is db.
Thank you very much
Rafi
(7,686 Views)
For zooming  drag over the portion of the graph you wish to zoom into. If you take a look into the method help for the .fft it specifically talks about all of the outputs and give a link to another document that discusses the Fast Fourier Transform itself.
If you are looking to plot power versus frequency I recommend checking out the example located at
 C:\Documents and Settings\All Users\Documents\National Instruments\MStudioVS6\VB\Samples\Analysis\Spectrum\Power Spectrum
Richard S -- National Instruments -- (former) Applications Engineer -- Data Acquisition with TestStand
(7,662 Views)
I Richard,
I was looking at this exact example and apparently this is what I was looking for.
However, I have few more questions:
1.  How to set the Y-Axes to show db
2.  How to calculate the energy of the 1st harmonic, 2nd harmonic,  3rd harmonic
Thanks for your support
(7,657 Views)
Since in this example we're getting back the spectrum you can pull out the y values and take a logarithm on them. I'm familiar with Measurement Studio, but not familiar with a "1st harmonic" calculation in reference to a fast fourier transforms.
(7,647 Views)
