Measurement Studio for VB6
Run-time error 30013
We're using PXI-6259, and installed NI-DAQ 8.0.1, but still using Measurement Studio 6.0. When I used "CWDI1.Configure", got error "Run-time error 30013", said " Newer Version of NI-DAQ require". Could somebody know the reason? Thnaks in advance.
Yingmai
(7,465 Views)
Hello Yingmai,
Thanks for posting to the forums.  The CWDI control that you mention is one of the CWDAQ ActiveX controls that installs with the Traditional NI-DAQ driver.  You can check which version of the Traditional NI-DAQ driver you have by expanding the Software category in MAX.
When you run through that installer, make sure that "Support for Visual Basic 6.0" is selected in the hierarchical view of components to install.  If you already have that verison, go to Add/Remove Programs, select "National Instruments Software," then find "Traditional NI-DAQ" in the list of software.  Click on it, then click the "Remove" button to uninstall it.  One the driver has been uninstalled, download and install 7.4.1.
I hope this helps.  If not, let us know and we can troubleshoot further.
(7,451 Views)
