Measurement Studio for VB6
Saving an imaq image to disk using CWIMAQVision
I'm not sure exactly why your code is not working. What I have been doing is going through the help documents trying to find calls that you can do without VDM. I came up with this method to save the image, but if that is not working, I might suggest going through the documentation to find other calls that can do the same thing.
Chris Van Horn
Message 21 of 56
(6,221 Views)
Does the CWIMAQ.interface have to be set to anything?  It's value is currently blank.
Message 22 of 56
(6,218 Views)
http://forums.ni.com/ni/board/message?board.id=200&message.id=11721&requireLogin=False
Take a look at this thread, on the second page one of your techs says
Hi -
Even if you don't have a license for Vision you can still use some methods on the CWIMAQVision control, including the File I/O methods such as WriteBMPFile.
Greg Stoll
Vision R&D
Message 23 of 56
(6,212 Views)
Hey,
If another engineer says that it can be done, its possible that it can be. However, in the documentation I looked in, it said that function (at least write PNG) fell under VDM, meaning you would need an active copy. I would try the BMP to see if that works for you.
As far as entering values, I did not need to enter any when I created that code, I just used the code I gave you. (This is for the original writePNG code) after creating a CWIMAQVision object on the fp.
Chris Van Horn
Message 24 of 56
(6,203 Views)
From your code:
CWIMAQ1.Interface = Text1.Text
What have you defined Text1 to be?
Message Edited by timmkish on 11-19-2008 01:02 PM
Message 25 of 56
(6,199 Views)
That was part of the example, and was left as default.
The only thing I added at all was the vision object and the one line of code.
Chris Van Horn
Message 26 of 56
(6,194 Views)
Here's what the error looks like
Message 27 of 56
(6,187 Views)
Hey timmkish,
I'll look into it some more, but I don't believe that you need the () where you are getting your error, I did not have that and my code worked.
Since we are having so much trouble with this, I might reccomend opening an example, running a simple snap with no save, making sure it works. Then adding only the save line of code. Nothing else extra, just to make sure that you can do this before implementing the wait.
Chris Van Horn
Message 28 of 56
(6,172 Views)
Chris,
That's what I'm trying to do.
Except all of the Snap examples I've opened thusfar, do not have an CWIMAQ object on the form.  So I have to do two steps, add the CWIMAQ object in the designer window, then add the single line of code.  I've tried doing that and I'm getting that same error.
Message 29 of 56
(6,168 Views)
Actually, I just found an example code in
F:\Documents and Settings\All Users\Documents\National Instruments\NI-IMAQ\Examples\MSVB.NET\Triggered Sequence\Triggered Sequence.vbp
that has the CWIMAQ object already part of the code.  Without modifying any part of the example code, running the program generates the exact same interface error on this line
CWIMAQ1.LoadInterfaceDefaults()
What is interesting is the previous three lines of code:
CWIMAQ1.Images.RemoveAll()
CWIMAQ1.Images.Add(NumBuffers)
CWIMAQ1.Signals.Item("TriggerLine1").Initialize(LineType.SelectedIndex, NationalInstruments.CWIMAQControls.CWIMAQSignalActions.cwimaqCaptureStart,
                               NationalInstruments.CWIMAQControls.CWIMAQSignalPolarities.cwimaqActiveHigh, LineNumber.SelectedIndex)
execute fine!  So the CWIMAQ object is at least partially behaving.  It's something to do with the CWIMAQ interface that keeps causing the error
Message 30 of 56
(6,167 Views)
