Measurement Studio for VB6
Sending messages to CW++ UI Controls
My apologies in advance if this is not a pertinent place for this question,
as I suspect it is as much an Active X control basics question as a CW++
question.
I am using Measurement Studio 1.0, the CW++ (Tools for C++) portion along
with MS Visual Studio 6. I have an MFC application that has several
modeless dialogs containing CW++ user interface controls. The application
also establishes a sockets-based server. Some of the messages received
through the sockets interface are intended to have the same action as a user
manipulating one or more of the CW++ user interface controls. For example,
I have a CNiButton based control for a camera shutter on one of the dialogs
with two states, Open and Closed. One of the mes
sages receivable on the
socket interface is to Open or Close the shutter.
Is there a method to send a message to the CW++ control that simulates the
mouse clicking the button to the Open or Closed state? This is my desire,
as then the actual control of the shutter device and state of the CNiButton
are always in synch and linked.
I have similar needs with other CW++ user interface controls.
TIA,
Mark Greenman
Space Dynamics Laboratory
Utah State University
Logan, UT
markg@sdl.usu.edu
(3,654 Views)
Mark,
If you set the Value property of the control in your program, it changes as
if the user had clicked it. For example:
m_button.Value = !m_button.Value;
toggles a CNiButton control. This is standard behavior for ActiveX controls.
The MeasurementStudio ActiveX controls have DataSocket binding, which you
might consider using instead. If you publish the data using DataSocket
instead of your socket server, you can configure the control such that its
Value property is automatically bound to the DataSocket data source.
David Rohacek
"Mark Greenman" wrote in message
news:3a07201d@newsgroups.ni.com...
question,
> question.
user
example,
dialogs
> with two states, Open and Closed. One of the messages receivable on the
CNiButton
> TIA,
> Mark Greenman
> Logan, UT
> markg@sdl.usu.edu
(3,654 Views)
