Measurement Studio for VB6
Single Plot fill with different colours
Hi;
Any suggestions on how I could fill a single plot with 2 different colours.? Basically I have a single sine wave trace. I want to fill the plot on the positive gradient of the sine wave with red and the negative gradient with green. I need to do this with measurement studio and VB6.
Thanks.
(6,946 Views)
Hi Dayaa,
There is no straightforward way to do this. You will need to use two plots. To plot these plots you will need to use the PlotXY function instead of the PlotY function. That will allow you to specify the X values for each plot so they show up properly. This forums post should help you out:
http://forums.ni.com/ni/board/message?board.id=231&message.id=692&requireLogin=False
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(6,928 Views)
