Measurement Studio for VB6
Spice Netlist does not work in EWB5
I'm a German teacher and tried to use theSpice-Netlist on_pwm.lib (found at url: http://www.cadence.com/downloads/orcad/files/pspice_models/on_pwm.lib ) to
simulate the flyback circuit example given in the datasheet of the
NCP1200 controller. I use the program Electronic Workbench in Version 5,
because therefore our schools got a license. The simulation did not run,
the program gave following alerts:
- Could not find subcircuit definition for "source"
- Could not find subcircuit definition for "pulses"
- Could not find subcircuit definition for "TD={250ns}"
- Could not find subcircuit definition for "delay"
- Could not find subcircuit definition for "UVLOh"
It was given the information that it is a "Parser-Error"
It will be very kind, if you help me. The simulation is part of a thesis
I have to write about my teaching!
Sincerly
Andre Große-Venhaus
(8,343 Views)
Dear Mr. Groß-Venhouse, in following link explained how to import new model in multisim: http://zone.ni.com/devzone/cda/tut/p/id/3173 In Step 6 you the the spice model by loading from file button you select there your *.lib Then you remove the other models you don´t need because you can only import one model and there are more models. The Component Wizard (Bauteileditor, Bauteil erzeugen, neues Bauteil unter Werkzeuge/Tools) combine the footprint with pins and model - so you can work with it. The link is for Multisim 9 but identical for former multisim versions. I don´t have EWB 5 but it must work by a similar way... Here´s an example of one model of the *.lib from your link .SUBCKT MC33363/ON 1 3 4 6 7 8 9 10 11 16 + PARAMS: RDSON=14 * STR VCC GND RT CT REG COMP VF OVL DRAIN **** ISUPPLY **** GSUPP 3 4 VALUE = { IF( V(33)<3.5, 250U, 3.5M ) } **** REFERENCE VOLTAGE **** EREF 80 4 VALUE = { IF( V(3)<7.7, V(3)-1.2, 6.5 ) } ROUT 80 8 10 **** STARTUP AND UVLO **** XUVLO 3 81 UVLO_33363 XOVL 60 11 82 COMP2_33363 GSTRT 1 3 VALUE = { IF( V(81)<3.5, (14M*((14-V(3))/14)+6M), 40U ) } XAND 81 82 33 AND2_33363 **** OSCILLATOR SECTION **** GCHG 4 7 VALUE = { IF( ((V(INV1)>500M) & (V(33)>3.5)), I(VIRT)*4, 0 ) } GDIS 7 4 VALUE = { IF( V(INV1)<500M, I(VIRT)*4, 0 ) } DUV 7 33 DUV VSET 21 4 1.25V VIRT 21 6 VREF1 22 4 2.5V RI 22 23 40K RF 23 INV1 10K ECMP CLK 4 VALUE = { IF( (V(7)-V(23)>0), 5, 0 ) } EINV 25 4 VALUE = { IF( V(CLK)<500M, 2.5, 0 ) } RDEL1 25 INV1 100 CEL2 INV1 4 100P **** PWM AND LATCH **** XPWM 7 9 31 COMP2_33363 XOR1 33 31 32 34 OR3_IN_INV_33363 XNAND1 34 CLK 35 AND_IN_INV_33363 XFFLOP 35 34 36 37 FFLOP_33363 XNAND2 CLK 36 33 450 3 AND3_IN_INV_33363 RDRV 450 DRV 100 **** ERROR AMPLIFIER **** VREF2 60 4 2.6V XERR 60 10 9 4 ERRAMP_33363 ; + - OUT GND **** CURRENT LIMIT COMPARATOR **** RLIMIT 40 4 450 G225 4 40 VALUE = { I(VIRT)*2.25 } XCOMP 50 40 32 COMPDEL_33363 **** MOSFET MODEL **** CIN DRV 4 200pF SMOS 16 71 DRV 4 MOS VISRC 71 4 **** KELVIN AND L.E.B. **** GIKEL 4 50 VALUE = { IF( V(DRV)>V(3)-0.7, I(VISRC)/51.2, 0 ) } RKEL 50 4 9 .MODEL MOS VSWITCH (RON={RDSON} ROFF=1MEG VON=3 VOFF=1) .MODEL DUV D RS=100M TT=50N CJO=10P N=0.1 .ENDS **** DELAYED COMPARATOR **** .SUBCKT COMPDEL_33363 1 2 3 * + - Out E1 4 0 VALUE = { IF( V(1) > V(2), 1V, 0 ) } RT 4 5 100 CT 5 0 3.36NF E2 10 0 VALUE = { IF( V(5) > 500M, 5V, 0 ) } RD 10 3 100 CD 3 0 100P .ENDS **** UVLO CIRCUIT **** .SUBCKT UVLO_33363 1 3 * VIN OUT Vref 10 0 5V X1 10 3 1 0 SWhyste_33363 params: RON=1 ROFF=1MEG VT=12 VH=2.5 RUV 3 0 1k .ENDS **** T FFLOP Circuit **** .SUBCKT FFLOP_33363 6 8 2 1 * S R Q Q\ EQB 10 0 VALUE = { IF ( (V(8)<800M) & (V(2)>800M), 0, 5V ) } EQ 20 0 VALUE = { IF ( (V(6)<800M) & (V(1)>800M), 0, 5V ) } RD1 10 1 100 CD1 1 0 10P IC=5 RD2 20 2 100 CD2 2 0 10P IC=0 .ENDS **** 2 INPUT, ONE INPUT IS INV, AND CIRCUIT **** .SUBCKT AND_IN_INV_33363 1 2 3 * INV NINV OUT E1 4 0 VALUE = { IF( ((V(1)<3.5V) & (V(2)>800M)), 5V, 0 ) } RD 4 3 100 CD 3 0 10P .ENDS **** 3 INPUT, ONE INPUT IS INV. AND CIRCUIT **** .SUBCKT AND3_IN_INV_33363 1 2 3 4 6 * INV NINV NINV OUT VCC E1 5 0 VALUE = { IF( ((V(1)<3.5V) & (V(2)>800M) & (V(3)>800M)), V(6), 0 ) } RD 5 4 10 CD 4 0 100P .ENDS **** 3 INPUT, ONE INPUT IS INV. OR CIRCUIT **** .SUBCKT OR3_IN_INV_33363 1 2 3 4 * INV NINV NINV OUT E1 5 0 VALUE = { IF( ((V(1)<3.5V) | (V(2)>800M) | (V(3)>800M)), 5V, 0 ) } RD 5 4 100 CD 4 0 10P .ENDS **** 2 INPUT AND CIRCUIT **** .SUBCKT AND2_33363 1 2 3 E1 4 0 VALUE = { IF( ((V(1)>800M) & (V(2)>800M)), 5V, 0 ) } RD 4 3 100 CD 3 0 10P .ENDS **** 2 INPUT NOR CIRCUIT **** .SUBCKT NOR2_33363 1 2 3 E1 4 0 VALUE = { IF( ((V(1)>800M) | (V(2)>800M)), 0V, 5 ) } RD 4 3 100 CD 3 0 10P .ENDS **** 2 INPUT COMPARATOR **** .SUBCKT COMP2_33363 1 2 3 * + - S E1 4 0 VALUE = { IF( (V(1) > V(2)), 5V, 0 ) } RD 4 3 100 CD 3 0 10P .ENDS **** ERROR AMPLIFIER MODEL **** .SUBCKT ERRAMP_33363 20 8 3 21 * + - OUT GND RIN 20 8 8MEG CP1 11 21 11.5P ; {1/(6.28*(GAIN/100U)*POLE)} E1 5 21 11 21 1 R9 5 2 5 D14 2 13 DMOD ISINK 13 21 2.7U ; {ISINK/100} in mA Q1 21 13 16 QPMOD ISOURCE 7 3 100u ; {ISOURCE} in uA D12 3 7 DMOD D15 21 11 DCLAMP G1 21 11 20 8 100U V1 7 21 5.8 ; Vhigh - 0.6V V4 3 16 250M ; Vlow - 38mV RP1 11 21 125.9MEG ; {GAIN/100U} .MODEL QPMOD PNP .MODEL DCLAMP D (RS=10 BV=5 IBV=0.01) .MODEL DMOD D TT=1N CJO=10P .ENDS **** .subckt SWhyste_33363 NodeMinus NodePlus Plus Minus PARAMS: RON=1 ROFF=1MEG + VT=5 VH=2 S5 NodePlus NodeMinus 8 0 smoothSW EBcrtl 8 0 Value = { IF ( V(plus)-V(minus) > V(ref), 1, 0 ) } EBref ref1 0 Value = { IF ( V(8) > 0.5, {VT-VH}, {VT+VH} ) } Rdel1 ref1 ref 100 Cdel1 ref 0 100p IC={VT+VH} Rconv1 8 0 10Meg Rconv2 plus 0 10Meg Rconv3 minus 0 10Meg .model smoothSW VSWITCH (RON={RON} ROFF={ROFF} VON=1 VOFF=0) .ends ***** END OF MC33363 INTERNAL MODELS ***** Hope i can help you Best Regards ApplicationsEngineer from NI Munich
(8,314 Views)
Additionally we have special prices for teachers and students - please contact NI Munich for quotes
Tel.: 0049 89 741 313 0 (CallCenter) or
Tel.: 0049 89 741 313 831 (EWB CallCenter)
or contact per email to
info@ewbeurope.com
info.germany@ni.com
support@ewbeurope.com
for prices to Upgrade to Multisim/Ultiboard 9
(8,311 Views)
