Measurement Studio for VB6
Two Pointer CWKnob
How can I get the values of pointers in a 2 pointer CWKnob without using CWKnob1_PointerValueChanged event. When ever I use CWKnob1.Value, it defaults to Pointer #1 value. How can I read the value for Pointer#2? I have attached a PDF to help explain.
(3,263 Views)
You can index into the Pointers collection and get the Value property for a particular pointer index, like so:
CWKnob1.Pointers(2).Value
Abhishek Ghuwalewala
Abhishek Ghuwalewala | Measurement Studio | National Instruments
(3,263 Views)
I have found the solution using
CWKnob.Pointers.Item(1).Value
(3,263 Views)
Thank you for your prompt reply.
I found the solution before looking for your response.
Thanks again,
(3,263 Views)
