Measurement Studio for VB6
USB-6501 how to realize: fast PWM wave ?
Do While True
    bit = 1 - bit
    DAQmxErrChk DAQmxWriteDigitalLines(taskHandle2, 1, 1, 5#, DAQmx_Val_GroupByChannel, bit,     sampsPerChanWritten, ByVal 0&)
    ' this need 2m , too slow , how to faster ??
Is there any setting in DAQmx  to let USB-6501 faster output ??
(4,029 Views)
then "Next" above should be "Loop"
and
I found that the freq. is very not stable :  the width should is "2m", but "4.2mm" appears !
and how to faster ? such as , the width = 10us , output from USB-6501 ???
not stable freq.  2m.. 5mnot stable freq. 2m.. 5m
(4,024 Views)
I think this post answers your question:
As the USB-6501 relies on a software clock, the timing will not be as accurate as a device with hardware clock.
https://forums.ni.com/t5/Digital-I-O/NI-USB-6501/td-p/3238833
(4,002 Views)
I looked at the article you recommended, but it was different from  my problem.
He wants to control the duty cycle in the way of software cycle, so the software cycle needs very fast cycles.
My problem : when I set up just only one  port with the following function:
(VB6)
DAQmxWriteDigitalLines(taskHandle, 1, 1, 5.0, DAQmx_Val_GroupByChannel, 1, sampsPerChanWritten, ByVal 0&)
(the taskHandle is :
DAQmxCreateDOChan(taskHandle, "Dev1/port0/line0", "", DAQmx_Val_ChanPerLine)  )
the  function takes 2ms to exit, too slow !  and I just set only one IO port .    I cannot understand , while USB-6501 need  2000us to complete this function ??   How to reduce the delay ?
I have tried this :  (but not pass)
DAQmxCfgSampClkTiming(taskHandle, "", 10000#, DAQmx_Val_Rising, 10123, 1000)
(3,936 Views)
