Measurement Studio for VB6
USBTMC ISSUE with Lecroy HDO6054
I'm connecting my oscilloscope to my PC using USBTMC but my pc can't read it. I already refreshed it in NI Max and its not also showing in my device manager. Can somebody help me?
(9,508 Views)
1. Did you change the remote setting in osci?
I.e. go to support- about- remote- USBTMC
2. Try changing USB cable
(9,487 Views)
Yes, I changed it to USBTMC already and I have NI VISA installed on my PC. Should I install NI VISA on Oscilloscope too?
(9,480 Views)
Does the HDO6054 have its own OS? If so, you may need to enable it for external control (i.e. disable itself as the System Controller) so that the computer it's connected to can control it.
Applications Engineering
(9,471 Views)
Yes it does have an OS but I dont know how to enable it
(9,469 Views)
I found this on page 98 of the HDO6000 Operator's Manual that may enable you to use external control but I would consult Lecroy for further troubleshooting to set it up if that doesn't work.
http://cdn.teledynelecroy.com/files/manuals/hdo6000_om-a.pdf#page=98
(9,461 Views)
Xin chào,
Bạn đã giải quyết vấn đề đó chưa,
Lecroy của tôi cũng có vấn đề tương tự, tôi không thể khắc phục được.
Tôi có liên hệ để hỗ trợ tại Lecroy nhưng họ phớt lờ tôi: ((
(6,260 Views)
