Measurement Studio for VB6
Updating projects to v6
I just received my new Meas. Studio v6.0
Before I install it, I would like to resolve a few questions.
1. The installation instructions say to uninstall my current meas studio
prior to installation.
I have several projects that are in different stages of development, some
have been distributed to customers
others are in earlier stages. How can I update those projects to the new
controls?
2. Will uninstalling Meas Studio 1 break my current applications?
Thanks for the help in advance.
Steven Stiller
(3,246 Views)
The reason that you have to uninstall the older version of ComponentWorks and ComponentWorks++, to be replaced by Measurement Studio for Visual Basic and Visual C++ respectively, is because the .ocx files and plug-ins for the environments will conflict from both versions. Version 5.5.1 and 6.0 of CVI can reside concurrently on the same system.
When uninstalling ComponentWorks 3.0.1 and ComponentWorks 1.0.1 you should always back up your project files, but the uninstallation itself should not break your current applications or projects. When loaded they will simply contain the new versions of the controls, but to take advantage of the new features you will have to edit your source files and rebuild your apps.
As for your already distributed applications, just to mak
e it easier on your end-users, I highly suggest rebuilding your apps with the new controls, creating a new distribution package, and redistributing the new releases. This will help you avoid problems of registering the new controls on their systems, making sure the old ones are removed correctly, etc... If they just uninstall your old distribution packages and install the new ones, it will take care of this procedure for them.
Remember though, that good installation practices follow the order of; uninstalling, rebooting, and then installing the new software. Follow this and you'll be ok.
Jason F.
www.ni.com/ask
(3,246 Views)
