You should be receiving this error when trying to run applications using these controls on non-development machines. If you create an executable on the development machine, and just move the executable to another machine it should work ok. If you try to move the application using these controls to another machine and run the program in debug or try to develop the application more, you will receive the error. I also found a knowledgebase that might help if you are receiving the error when you shouldn't be.
http://digital.ni.com/public.nsf/websearch/60B1DE0C85624B55802568D90031AF89?OpenDocument
Hope this helps.
Steven B.
Applications Engineering
