Measurement Studio for VB6
Using value pairs with a cwgraph object
Whew, I finally figured out how to use these things!   Insert Smilies
However, I am wondering if I can change the orientation of the text ("Name") that is displayed next to the X-axis at "Value". If my Name is short, e.g. "A", the orientation is not a problem. If the name is long, i.e. "100 - 200", then the tick labels overlap each other.
Can this be done?
Thanks!
(6,421 Views)
Hi Steverino,
Unfortunately you can not change the orientation of the labels.  Increasing the graph size helps.
Have a great day,
Ecleamus Ricks, Jr.
(6,410 Views)
