Measurement Studio for VB6
VB Code problem
Dear All!
I want to use visual basic to build a htm which used to indicate the value of knob from labview through Datasocker.
But it can't work properly, the code as follow.
Private Sub CWKnob1_PointerValueChanged(ByVal Pointer As Long, Value As Variant)
CWKnob1.Value = CWDataSocket9.Data
End Sub
Is the code has problem?
Thank you very much
(3,050 Views)
You need to use the Value property of the CWData object. For example, the code above would be changed to this:
CWKnob1.Value = CWDataSocket9.Data.Value
End Sub
- Elton
(3,050 Views)
