Measurement Studio for VB6
VB6 freezing
Hello
I have an application made with Visual Basic 6.0 using RDO connection to connect to SQL 2000, I can run it on windows XP successfully. The problem begin after I installed SP2 for windows XP, when I run my application it freez a lot of times and not every time.
Many the problem will be solved if I change my connection from RDO to ADO. Hope you can help me.
Thank you
(5,685 Views)
Are you using NI Measurement Studio? This message board is for applications using National Instruments Measurement Studio and Visual Basic 6. So you might got find revelant help here. I personally don't have a lot of experience with databases and VB6, but you might try googling for one.
SijinK
(5,672 Views)
