Measurement Studio for VB6
Why is my CWButton LED switch from 3D Stye to Classic (saving or running?)
I was adding a LED to my Visual Basic form, and I switch the CWButton to a 3D Style LED. When I run the program the form shows it as a classic style. I convert it back to 3D.. then just save the form, it converts it back to classic style. I want to keep it in the 3D form.
Note: I have component works, LabView 6, CVI, etc (from Measurement Studios) installed.
(5,915 Views)
What version of Measurement Studio do you have installed? The 3D Styles are a feature of Measurement Studio 6.0, and you must have a licensed 6.0 or higher version of the Measurement Studio User Interface control installed in order to save the styles.
You can check the licensed version of the User Interface control on your machine by using the
Measurement Studio license fixer.
You can also use this utility to fix a broken license.
Nauman
(5,915 Views)
This worked!! Thanks so much. It was a corrupt license with my UI Controls. All other licenses were okay.
(5,915 Views)
