Measurement Studio for VB6
Wide Screen CWKnob dial will not go circular
Hi - In adapting a VB6 application for 16 x 9 wide, I can find no way to make the dial on a CWKnob control be circular, or indeed to change the aspect ratio at all. The only property that might affect it is the Image.Stretch property, which is greyed in the properties window. Again, no matter what I do. Besides it is apparently set to True which I imagine is what would be required for the dial to fill the available space.
Please let me know what I am missing, or give me some kind of workaround. Thanks!
Stephen M-L
(7,196 Views)
Hello Stephen,
There is not a way to change the aspect ratio, however you should be seeing a circle currently. Please let me know if that is not the case.
With warm regards,
David D.
(7,185 Views)
Hi - The dials were circular on the original design on a 4:3 display and we would like them to remain so. On the 16:9 display version all dials show as elongated ellipses and look lousy. Are you telling me we are stuck with this?
Regards, Stephen M-L
(7,165 Views)
Stephen,
That's very strange. Could you take a screenshot? What is the resolution of the screen you are looking at? Was this application created then deployed or are you placing new controls down and this is happening?
With warm regards,
David D.
(7,163 Views)
