Measurement Studio for VB6
Window 7
I have an excel visual basic program working good using XP.
After I changed to a new computer with window 7, it.s not working properly.
I used stardard library for VBA from NI, NIGLOBAL and VBIB32.
Are there any new libraries files I should update?
regards
Mindy_Gortling
(7,841 Views)
Greetings Mindy,
Are you using Visual Studio with Measurement Studio? Which versions?
Also, what isn't working after you migrated to Windows 7?
Brandon V.
(7,821 Views)
HI, Brandon
In XP computer, I used excel visual basic, I followed the instruction on https://forums.ni.com/t5/Example-Code/Language-Interface-32-bit-Microsoft-Visual-Basic/ta-p/3996038, down loaded example900218.zip, added VBIB-32.BAS and NIGLOBAL.BAS to my program as basic subs.
Readme file as this:
Win32 Microsoft Visual Basic Language Interface
Version 1.1.
Copyright 1998 National Instruments Corporation.
All Rights Reserved.
The \VBASIC\VER4 subdirectory contains the following:
README.TXT - This readme file
VBIB-32.BAS - Visual Basic source file with NI-488.2 routine
and NI-488 function prototypes
NIGLOBAL.BAS - Visual Basic global module containing certain
predefined constant declarations
DEVSAMP.MAK - Visual Basic device-level sample project file
DEVSAMP.FRM - Visual Basic device-level sample form file
SAMP4882.MAK - Visual Basic NI-488.2 sample project file
SAMP4882.FRM - Visual Basic NI-488.2 sample form file
\OCX - Subdirectory containing the Visual Basic GPIB OLE
control code and device-level sample project file.
Now I changed a new computer using Window 7, do you have similar 64 Version program?
Mindy_Gortling
(7,816 Views)
Mindy_Gortling
There are not going to be example programs for VB6 for Windows 7 64-bit.
Take a look at this thread http://forums.ni.com/t5/Measurement-Studio-for-VB6/VB6-application-using-GPIB-fails-in-Windows-7/td-...
(7,811 Views)
