Measurement Studio for VB6
acquisition signal analog input DAQ usb 6008 using Excel Visual Basic
Dear Srs
I have a doubt that urges me to solve it as soon as you have if you help me I will be very grateful.
Is:
I have to acquire analog signals in a USB DAQ 6008 National Instrument, for it must create an application in  Excel Visual Basic, the data acquired from different analog input channels must be stored in an Excel spreadsheet in the same application and draw if possible graphs in real time.
Can you do this with Excel Visual Basic?
I could help with this issue, any help on this would be welcome
Thanks in advance
Greetings to all
(7,136 Views)
You should be able to do this from Excel's VBA since VBA is very similar to Visual Basic 6.
When you install NI-DAQmx which is needed for the USB 6008, be sure to verify that it installs what you need to Visual Basic 6.
When the installation is done, you should have example programs in the NI-DAQ directory.
(7,116 Views)
