Measurement Studio for VB6
aquiring analogue data
ive got a digitized signal coming in to the serial port on the PC. this is coming from custom built hardware. ive seen sum reference to NIVisa for reading in data. do i need any special hardware? what driversdo i need. id like to be able to continously plot this data. ive got the evaluation version for VB6.
thnx
hope to hear from u soon
(7,027 Views)
Hello kalice,
Yes, you can use NI-VISA to read from and write to a serial port.  You would need to have NI-VISA, current version found here, and NI-Serial, current version found here, installed on that machine.
These drives will also install examples on your machine.  The Serial Read is also a good example to try.
Meghan
(7,020 Views)
