Measurement Studio for VB6
canopen through visual basic
Hi i am new i in working with canopen,i am in compulsion to acquire canopen based encoder through visual basic 6 than labview,can anyone suggest the configuration which i need to make in visual basic for the same....
    the hardware wich i have to acquire is pci can series 2
if someone can sendsome example to acquire the canopen datas through visual basic it will be very helpful &....
i am eagerly waiting for  all ur reply
(7,911 Views)
I could not find any examples for VB and CANopen. You could try to program it by using the Frame api;  a fairly good knowledge of NI CAN and CANopen would be needed to do this.  I know you said you wanted to use VB, however NI does have a CANOpen LabVIEW Library which will work with all High Speed Series 2 cards.  The library does not have support for other languages however, so it will not work with VB 6.
Adam W
Applications Engineering
(7,896 Views)
hi thank s for suggesting..
can anyone brieflly tell the configuration which i need to do for canopen in vb to retrieve datas....
(7,888 Views)
