Measurement Studio for VB6
change inputs from single ended to differential at run time
I have a software package written that reads in analog values using a 6014 DAQ board. I want to allow it so that the user can select (at run time) whether the inputs are single ended or differential. This would be stored in a database and saved.
I am reading in the analog values using a CWAIPoint. I don't see anywhere where you can specify the Input Mode for a CWAIPoint at run time?!
Am I missing something?
Any help would be appreciated!
CM
(3,556 Views)
Sorry, just found the answer. First time I've answered my own question.
CWAIPoint1.Channels(X).InputMode =
Where X is the channel string. Intellisense will give you a list of input modes if this is typed in.
(3,556 Views)
