Measurement Studio for VB6
cw3dgraph surface not displayed
Hello All,
I am using the cw3Dgraph component in VB6 and have some trouble plotting surfaces.
I use the function Plot3DSimpleSurface.
I have set-up the properties so that the graph should be a surface. But the data is plotted as lines, not surface.
Any suggestion?
Many thanks
(6,499 Views)
Hi Atacama,
Could you post your code so I can see how you are using the function? There is a related example but in C++ on the following link, which may help: http://zone.ni.com/devzone/cda/epd/p/id/3807
Imtiaz Chowdhury
Project Manager
Green Running / Austin Consultants
(6,487 Views)
