Measurement Studio for VB6
cwgraph multiplot[VB]
I want to make a graph using cwgraph with a 3 dimensions var. but just take the two last dimension as data....
i explain :
i got for example : plotdata(2,5,5)
i want to trace plotdata as if it was just plotdata(5,5) but without using another var...
i try cwgraph.ploty plotdata(1) bur it on't work is there a solution or do i have to use another var???
(3,127 Views)
I don't see any way to use one declaration variable which is a three dimensional matrix already, as in your case. The only way that I am familiar with is the CWGraph3D1.Plot3DCurve ArrayX, ArrayY, ArrayZ. This takes three input arrays representing your X values, Y values, and Z values. In your case, it may be best if you were to "break" up your one large 3D array into three samller vectors, and go from there.
(3,127 Views)
