Measurement Studio for VB6
cwgraph3d gray lines in plot area
It is just me, or does a cwgraph3d always have a 2 gray lines inside of it on the right and bottom. I can't seem to get rid of these. I don't want them there because when I take the ControlImageEx(0,0) it brings the gray lines also.
(6,366 Views)
Hi BillyBobJr,
I'm not sure if I see the gray lines that you are referring to. Is there any way you can send me a screen shot of what you're seeing to see if these lines are expected or somehting that is out of the ordinary. I'll take a look at them and go from there. I look forward to your post. Thanks.
Adam B.
(6,348 Views)
The graph has some data in it to show that the lines aren't part of the data but part of the graph. I have pointed the line out with a big pink arrow.
(6,340 Views)
TheBillyBobJr,
Sorry about the delay in responding. I spoke with our R&D group about the grey lines that you are seeing and they let me know they are result of the windowed designed of the control. The main reason you are seeing the lines in your particular situation is that you've changed your Graph Frame Color. You should be able to keep your black background and modify your frame color to alter the look of these grey lines. I apologize that there isn't a better answer for you but these lines are a result of the design. Let me know if you have additional questions. Have a good one.
Adam B.
(6,252 Views)
