Measurement Studio for VB6
how to used parameter in example program with visaul basic
i have some proplem about away to used parameter in visual basic example program for ex. As Status ,As ViSession because it can't complier
(3,126 Views)
Jone –
Greetings from National Instruments! I hope you are finding your use of the Developer Exchange discussion forum advantageous. We really believe that this is a great resource for programmers to gather and work with each other, sharing tips and working together to answer questions.
I am not 100% sure about which specific Visual Basic you are inquiring. However, the NI-VISA User Manual contains many specific Visual Basic examples that I think would greatly help you in these programming pursuits. I would suggest that you take a look at this link (http://digital.ni.com/manuals.nsf/websearch/266526277DFF74F786256ADC0065C50C?OpenDocument&node=132100_US), specifically Appendix A. There you will find many examples, including specific declarations,
which I think is the point of your entry here.
I hope that this helps you out! Thanks again for your support of National Instruments and your use of the Developer Exchange!!
Best Regards,
Greg Wempe
(3,126 Views)
