Measurement Studio for VB6
problem with examle code VB 6 Analog output
Hello
sorry for my bad english 🙂
Now I explore NI USB-6008. Work with VB6
2 days cant understand why don't work example programm for Analog Output - Cont Gen Volt Wfm-Int Clk
Example programm for Analog Input  - Is Work very good, but AO :(...
error -200077 in line:
'DAQmxErrChk DAQmxCreateAOVoltageChan(taskHandle, physicalChannelTextBox.Text, "aoChannel", minValueTextBox.Text, maxValueTextBox.Text, DAQmx_Val_VoltageUnits2_Volts, "")
 instead of this i try replaec parametrs on their codes... as that so has turned out:
DAQmxErrChk DAQmxCfgSampClkTiming(taskHandle, "", 100#, 10280, 10123, 100)
and now i have error -200077 in line:
'DAQmxErrChk DAQmxCfgSampClkTiming(taskHandle, "", 100, clockEdge, DAQmx_Val_AcquisitionType_ContSamps, 100)
Once again forgive for my bad English
In advance thanks
Message 1 of 10
(15,154 Views)
now i find in http://forums.ni.com/ni/board/message?board.id=230&thread.id=4097
peace of code:
DAQmxErrChk DAQmxCreateTask("", taskHandle)
DAQmxErrChk DAQmxCreateAOVoltageChan(taskHandle, "Dev1/ao0", "", 0, 5, DAQmx_Val_Volts, "")
DAQmxErrChk DAQmxWriteAnalogScalarF64(taskHandle, 1, 10#, 1#, "")
i try him, and:
in second line i have error 200077, but if i replace  DAQmx_Val_Volts on 10348 then i have error -200492 in third line "Reversed parametr must be Null" i dontunderstand nithing now 😞
what i do not right?
Message 2 of 10
(15,151 Views)
I fink that at me a problem in clockEdge, but I will not understand as it to solve: (
this parametr can be:
1)DAQmx_Val_Edge1_Rising
2)DAQmx_Val_Edge1_Falling
and 1 and 2 not work 😞
Message 3 of 10
(15,149 Views)
It again I:) I try to make through  DAQmxWriteAnalogF64 . I receive an error -200492 Reserved parameter must be NULL...
code:
    DAQmxErrChk DAQmxCreateAOVoltageChan(taskHandle, "Dev3/ao0", "", 0, 5, DAQmx_Val_VoltageUnits2_Volts, "")
    DAQmxErrChk DAQmxWriteAnalogF64(taskHandle, 2, True, 10, DAQmx_Val_GroupByScanNumber, 1, 50, "")
error in third line.... but i don know where 😞
Message 4 of 10
(15,140 Views)
It is necessary for me on 1 analog output to send only 1 value... Somebody help
Modul 6008   programmning on VB6
In MAX all works right
Analog input too work perfectly - analog output do not want...
I read many tutorials, many posts, advices - but nothnig help ...
Vitaliy
Message 5 of 10
(15,136 Views)
    DAQmxErrChk DAQmxCfgSampClkTiming(taskHandle, "", 150, DAQmx_Val_Rising, DAQmx_Val_AcquisitionType_FiniteSamps, CLng(25))
in this line i get error  200077. Please tell me, why it so? I work withNI USB 6008. Programming on VB6
Vitaliy
Message 6 of 10
(15,106 Views)
Hi Vitaliy,
I appreciate your persistence working with your application. It sounds like you are trying to configure parameters in your code that may be out of range or not supported by your device. I did find an example using DAQmx in VB6 that generates single point AO. I think this may be a great place for you to work from and may provide the functionality you are looking for. I have included a link to the example below for your reference. There are also additional examples that should be installed on your computer and I've included a link that describes this in more detail, but these examples should include the correct formatting of the commands.
You may still run into an issue if your parameters are not allowed for your particular model of hardware. If you are still running into issues could you supply more information about the values that your are writing to each command? At this point you have variables in your code, but I am not if there is a particular parameter that is causing your problems.
NI-DAQmx: Generate Single Point Analog Output In VB 6
http://zone.ni.com/devzone/cda/epd/p/id/5338
NI-DAQmx Examples for Visual Basic 6.0
http://digital.ni.com/public.nsf/allkb/735848148B5B4964862571F5004692C7?OpenDocument
Steve B
Message 7 of 10
(15,085 Views)
Hi Steve
Thanks big.
Your Example has opened my eyes. All genious is simple:
All worked initially, it was necessary to restart simply the unit after appearance of an error 200492 and to write in string DAQmxWriteAnalogScalarF64 (............, ByVal 0)
But I what for tried to write that there Null or ""
It realy my mistak - i not attentively reading description of functions and errors
Once again thanks
I will go to study the modul further
Vitaliy
Message 8 of 10
(15,071 Views)
Hi, Vitaliy
i know this is an old post but i am reaching out to you because i have searched through and tried everything in my power to get the analog input of Ni6008 using vb6 and have not been successful. could you please point to to the right direction. Could you please share an example with me.
thanks.
Roy
Message 9 of 10
(8,988 Views)
Hello, do you have 6008 communication with VB now? Can you give me some guidance? Thank you!
Message 10 of 10
(8,783 Views)
