Measurement Studio for VB6
"Newer Version of NIDAQ require"
I am using VB6 on NIDAQ 6024E I am getting runtime error(30013) at cwai1.configure "Newer version of NIDAQ required". I am using win2000 please help
(3,969 Views)
I am not sure what version of NI-DAQ you have installed, but I would recommend that you go to the Add/Remove Programs section of Windows 2000 (Start->Settings->Control Panel->Add/Remove Programs) and removing your version of NI-DAQ and installing the lastest version of NI-DAQ from the web.
You can find the NI-DAQ driver on the web at www.ni.com/support and follow the downloads link.
Read the install.txt file for instructions on how to install NI-DAQ. The current version is NI-DAQ 6.9.1
Thank you and good luck with your project.
(3,968 Views)
Thanx Michale!
I am using version 6.5.1 and my device is pci-6024e DAQ
Some time before(1 week) everything was working fine.
But after formatting my system when I reinstalled everything, "Newer version of NIDAQ required" error start coming. Before this error onr more error come which is "Run Time error -2147418105(80010007) Automation server The Callee (server[not server application]) is not available or disappeard;all connection are invalid.The call may have executed."
Please help me in solving this problem
Regards
(3,968 Views)
Well, I have not seen that error before, but here are some things to check on. One make sure you uninstalled the older version of NI-DAQ before you installed NI-DAQ 6.9.1. If not, go to Add/Remove Programs and remove both version of NI-DAQ and reinstall NI-DAQ 6.9.1.
Other than that I am not sure what you are doing or what application you are running or launching when you get this error. Also, NI-DAQ 6.5.1 is not supported on Win 2000.
(3,968 Views)
