Hi all,
i'm doing continuous data acquisition from 16 lines with a daqcard6533 and measurement studio for vb6. I need to start the acquisition on the first leading edge of one of the lines, selected by the user. Using the CWDI control i could not find anything for setting the trigger...i know that the function to call should be DB_TRIGGER_CONFIG, but if i call it explicitly in the code, i get the following message:
"no group is assigned, or the specified line or channel cannot be assigned to a group"
thanks for any help..
walter
