Measurement Studio for VB6
simulated device with visual basic 6.0
It is possible to run a VB application using simulated devices? I have created a simulated PCI6024E, but my VB application does not find the device.
Thanks.
(5,813 Views)
The simulated DAQ devices only work for DAQmx. If you are using the CWDAQ activex controls, you will not be able to see them becuase these activex controls use Traditional DAQ. You can use VB 6.0 with DAQmx. Refer to this KB for more information.
Bilal Durrani
NI
(5,802 Views)
