Measurement Studio for VB6
stuck in a vb do loop
Hello from a newbie,
I can't figure out why I can't get out of my do while loop, please look at following code:
Public Sub cmdStart_Click()
Dim data As Variant
Do While cmdStart.Value = True
CWAIPoint1.SingleRead data
CWGraph1.ChartY data
DoEvents
Loop
End Sub
I can click on the button while the loop is executing, but the value won't change to false. I think this is probably more of a vb question, but any suggestions are greatly appreciated.
thanks,
Brian
(3,128 Views)
The problem is that the VB CommandButton control does not change its value by clicking on the control. For example, create a new VB project, drop a CommandButton on the form, double-click on the button, and add the following code:
Private Sub Command1_Click()
MsgBox Command1.Value
End Sub
Notice that the MsgBox displays "True" every time that you click the control. Try using CWButton instead of CommandButton.
- Elton
(3,128 Views)
