12-13-2005 10:45 AM
12-14-2005 07:27 PM
12-14-2005 07:32 PM
12-15-2005 05:43 PM
12-15-2005 05:54 PM
12-15-2005 07:43 PM
To clarify, I have two CWGraph issues.
In one of them I can use any frequency and sampling rate I like. This is what we talked about today.
Yesterday we talked about a graph in which I am restrained to getting data at 250 hertz, with each cycle being 3 seconds.
Will you be posting anysample code tomorrow? I'll look at it and talk to you if I have problems. Thanks so much,
saroj
12-16-2005 04:32 PM
12-29-2005 10:52 AM
Hello Caroline,
I did manage to get the scrolling effect based on your sample app. The timer in your app was not obvious to figure out how to improvise with the actual DAQ board, but its working now. A side effect is that since I have to replot so many times the time axis values increase astronomically and I dont see a way to get the numbers to be 'actual'. With the previous way (non scrolling) the numbers of time slide along like they should e.g 6->9-12 etc.
Now they are 6->4500->9000 etc and its because I'm plotting in a loop. Is there a way to regain control of the time axis in the numbers it displays? It keeps the range like I tell it to, but the values arent what I want them to be.
Thanks you and the other AE who helped you with the sample. Also thanks to all the other AE's Daniel, Tyler, Nandini, Scott and hope I didnt miss anyone,
saroj
01-03-2006 02:43 PM
01-05-2006 05:23 PM
