Measurement Studio for VB6
using measurement studio with my own circuit
Im a computer engineering student
I have designed a circuit which do analog-digital convertor and the computer reads the digital value from the parallel port, and Im looking for an application
I found this nice topic in your site : Measurement Studio Analog Output -- Waveform Generation in Visual Basic
http://zone.ni.com/devzone/conceptd.nsf/webmain/9C9F9227D165EF6C8625687E006CEFF5
and I hope that I can do it for my project
my question is : can I use the parallel port of the PC instead of National Instruments data acquisition (DAQ) hardware in the measurement studio 6.0 ??
thank you alot .
Bader
(6,357 Views)
no replays ??!!
(6,349 Views)
It sounds like your question is really if you can access the parallel port from your Measurement Studio Environment. The answer is yes, and one way to do this is using NI-VISA. In general, I imagine you will be performing viOpen, viRead, and viClose operations on your parallel port. The following discussion forum links should help you get more well rounded on the idea: (note: many of these forum posts have helpful links as well!)
1. http://forums.ni.com/ni/board/message?board.id=170&message.id=25066&requireLogin=False
2. http://forums.ni.com/ni/board/message?board.id=170&message.id=109253&requireLogin=False
3. http://forums.ni.com/ni/board/message?board.id=170&message.id=112975&requireLogin=False
4. http://forums.ni.com/ni/board/message?board.id=170&message.id=96478&requireLogin=False
5. http://forums.ni.com/ni/board/message?board.id=170&message.id=118167#M118167
6. http://forums.ni.com/ni/board/message?board.id=170&message.id=86769#M86769
Repost if you have further questions!
Best Regards,
JLS
Best,
JLS
Sixclear
(6,340 Views)
my friend what you are saying is correct
I need to access the measurement studio through the parallel port
so can I use the CWGraph to plot the data which read on the parallel port ??
or I have to use the Labview for this scope ??
but i dont have the labview ... is there an evolution version for it ?
thanks alot
(6,337 Views)
Bader,
Once you have gotten the data from your device using the parallel port and VISA as described above, you can easily view this on a graph. You will simple want to take a single double or an array of doubles and plot them using the CWGraph.PlotY function. Let us know if you have any other questions.
Adam B.
(6,312 Views)
