Measurement Studio for VB6
vb run-time error 5 Invalid Index run time runtime
I get an error on the red line when I execute this code.  Can someone please help.
CWIMAQViewer1.Attach CWIMAQ1.Images(ImageIndex)
CWIMAQ1.LoadInterfaceDefaults
CWIMAQ1.AcquisitionType = cwimaqAcquisitionContinuous
CWIMAQ1.Start
CWIMAQ1.Stop
Dim Image As New CWIMAQImage
Dim ImageType As CWIMAQImageTypes
Dim HistogramReport As New CWIMAQHistogramReport
Dim Value As Double
ImageType = cwimaqImageTypeU8
CWIMAQVision1.Cast Image, Image, cwimaqImageTypeSGL
CWIMAQVision1.Histogram2 Image, HistogramReport
CWIMAQVision1.Subtract Image, HistogramReport.Item(0).PixelRange.Min, Image
(9,974 Views)
Hi tres0422,
You are indexing an object that has not been initialized with the line HistogramReport.Item(0).  This results in your Invalid Index runtime error.  When you call Dim HistogramReport As New CWIMAQHistogramReport the resulting object has zero items.  You will need to add an object using HistogramReport.Add before you try to reference it in memory.
Ryan F.
(9,957 Views)
Ryan I totally appreciate your help.  Thank you.  I tried the histogramreport.add, but it didn't work.  I changed the ".item(0)" to an ".item(1).  Now I am getting another error.  "Run-Time Error 31006.  The Image is not large enough for the operation."  My concern is that I have not attached an image to the variable named image or that .item(1) is empty.  Can't tell which, any ideas?
Thanks,  Thomas
(9,950 Views)
Ok all is fixed now.  There is no histogramreport.item(0).  I could never get it to work.  Change the 0 to a 1 and it works.  I was making a mistake in the other part when assigning a value to Image.  I should have used a "Set".   Now all is good.  thanks Ryan for all of the help.
(9,939 Views)
Ryan,
    Here is the code.
Thomas
Private Sub Convert_click()
    Dim imGrab As New CWIMAQImage
    Dim Value As Double
'*****intSnapIndex is a public variable that is equal to the index number of the last valid Image Acquisition
    Set imGrab = CWIMAQ1.Images(intSnapIndex)
'*****  Start of code created by builder file from Vision Assistant
    CWIMAQVision1.Cast imGrab, imGrab, cwimaqImageTypeSGL
    CWIMAQVision1.Histogram2 imGrab, HistogramReport
    CWIMAQVision1.Subtract imGrab, HistogramReport.Item(1).PixelRange.Min, imGrab
    Value = IIf(ImageType = cwimaqImageTypeI16, 32677, 255) _
    / (HistogramReport.Item(1).PixelRange.Max - _
    HistogramReport.Item(1).PixelRange.Min)
    CWIMAQVision1.Multiply imGrab, Value, imGrab
    CWIMAQVision1.Cast imGrab, imGrab, ImageType
    CWIMAQViewer1.Palette.Type = cwimaqPaletteGrayScale
'***** End of code created by builder filer from Vision Assistant
    strfileext = "JPEG"
    Call Save_Click
End Sub
Message Edited by tres0422 on 02-02-2006 01:37 PM
(9,932 Views)
Thanks a lot Thomas.  Good luck in your application,
Ryan F.
(9,925 Views)
